Hi @fraguda,
How do I load a 3dm file from the local storage into the Rhino 3dmloader without involving servers? Is there a boiler plate code that I can refer to for this?
Hi @fraguda,
Are you running your application locally as well?
Right now yes. But I’m planning to deploy the viewer if this works. Similar to rview by Steve. But I’m having a hard time understanding his code since it’s too complex tbh. I’m looking for a simple native js example if one exists.
Ok. I guess you are still running your app with a local server. If so, you need to use the File API. We have a few examples of this, but they are part of another project. I will create a rhino3dm example with an upload function. In the meantime, check out this example:
There is the input element defined in index.html: compute.rhino3d.appserver/index.html at main · mcneel/compute.rhino3d.appserver · GitHub
and the code to get the file from the local file system in app.js: compute.rhino3d.appserver/app.js at main · mcneel/compute.rhino3d.appserver · GitHub
You would then need to read the file with rhino3dm with something like:
const doc = rhino.File3dm.fromByteArray(arr)
Thanks for highlighting that we need a good example here!
Thank you so much @fraguada. I’ll try this out. Please let me know when you have an example up. It will be of great help.
