Load GhPython.gha in Rhino 8
I put it into the Libraries folder and properties for unlock. I open grasshopper in Rhino8, but can’t see.
Anyway to load it, I can’t connect grasshopper with tekla structures, I want use old ghpython.
You don’t need to install it. Rhino 8 still ships with GHPython, but hides it from the user. You can find it by double clicking the canvas and searching #GHPython
I did same with Rhino 7 and Rhino 8, but can’t connect grasshopper in Rhino 8 to Tekla.
Why same Ghpython, but only Rhino7 working
It might be related to the updated .NET framework used in Rhino 8:
Rhino 7:
Rhino 8:
Thank you.
Do we have anyway install or change to old .NetFramework ?
I doubt it, but you’d have to ask one of the McNeel developers.
Hi -
You can use the SetDotNetRuntime command to change the runtime from the default NETCore to the Rhino 7 NETFramework.
Thank you, You save my day.
