I linked un dwg file in revit and I imported its coordonnates. When i try to llink a 3DM file which has the same coordonnates tham the DWG, well in REVIT, it is said that they do have the same systems but that the 3DM will be insert in the revit coordonnates, but in a second times, it is daid that thez do not have the same system and taht the 3DM file will be insert center to center…
I opened up Rhino and checked the units (meters), opened up a new Revit Project (2022) in metric and changed the units to Meters. Using Link Cad in the Revit Insert dialog i brought in the Cad Boundary and .3dm using the Origin to Internal Origin option on both.
Ok but now try first, to link the DWG, center to center, import its coordonnates, then link the 3DM file with shared coordonnates and you will see the problèm
I’m not quite following, what is determining the Center of the DWG? import it coordinates in what manner?? The 3DM isn’t going to know shared coordinates.
You may want to bring them in as shown above and then translate to a different coordinate system in Revit.
Here is the way to import DWG coordonates in REVIT from DWG. My question is Autodesk give the possibility th link the 3DM file with shared coordonates… I am dealing with Autodesk to understand…
