Lights which are not part of blocks are still accesible while block editing
As you can see in the image blow, I am still able to select the light on the left while editing the block on the right, even though the light is not part of that block.
This becomes a problem especially when I set up a scene for rendering and I have to constantly edit blocks and change lights. It is a problem in V5 as well, it would be very useful if you could fix it in V6. Thanks!
Hi, while you are at fixing this, could you look at lights from external renderers in blocks. e.g. vray spot lights in blocks do not emit light. might be vray related, i did not check with other renderers. thanks
Hi Bogdan - I see that, thanks.
https://mcneel.myjetbrains.com/youtrack/issue/RH-39420
RH-39420 is fixed in Rhino WIP
