Is it possible to set the leaf position in sliding door? It very important because in VA sliding door the position is not correct related to reality construction.
See attached
Thank you
See attached
Hi @fn_a,
That is not possible for now with a regular door style (I will check if we can implement it for future versions) but you can do t creating the style from a block or with a Grasshopper style.
are there any news about this implementation for sliding door style in VA3?
Thank you
Hi @fn_a in VisualARQ 3 we have added a parameter to control the alignment of leaves in relation to the frame:
Is that what you are looking for?
