I have a strange problem occuring with a linked block:
I’ve created in model A a set of leaders with an annotation style that has enabled the text to be horizontal to the view.
When i insert model A into model B as a linked block and I rotate the block, the text does not align to the view:
in front view:
in top view after rotating the block:
perspective view:
Is this a bug or is there a setting that I’m missing?
Thank you for your help,
Best Regards,
Victor
wim
(Wim Dekeyser)
2
Hi Victor -
I’m not seeing that here if I understand the instructions correctly…
Can you post the 3dm file?
Hi Wim,
See the attach model which corresponds to model A.
model A.3dm (141.5 KB)
SashankPs
(ShankBhai)
4
If its just to label in a screen space, take a look at dots
Thanks! - unfortunatly I use it in a page view and the dots dissapear when I have two cliping planes around them (when i try to create a section view)
wim
(Wim Dekeyser)
6
Hi Victor -
Thanks! I’ve put this on the list: RH-75332 Block: Text In Block Not Displayed Horizontal to View
