Hello to everyone,
Is it possible to extract a structured list of layers (including sublayers) from a Rhino file to an Excel list? It could be very handy, when working on projects of massive architectural scale. Also, would it be possible to have the process reversed, starting from an excel list, then generating an automatic list of layers?
Thanks
Luca
I have a script that does layer name export to .CSV if that helps. I have not written the opposite to import though - although it shouldnât be too hard to do, it would just depend on how the lines are structured vis-a-vis sublayers (i.e. separator).
ExportLayerNamesCSV.py (418 Bytes)
Thank you! I am going to try it immediately and come back to your shortly.
Luca
It does work well (sub-layers seem to be separated by a double colon :
on a generic file. Thank you.
In the specific file I have to manage, however, layers are actually in Chinese. Is this the reason why I am getting the following error?
Thanks
Luca
Yeah, probably because I didnât make any provisions for non-ascii characters. I tried fixing that, try re-downloading from the original link aboveâŚ
Thank you! I have just tried it and this is what now I get:
Luca
OK, I donât know if the lines of code I added work for Chinese characters, itâs intended for extended ascii characters like letters with accents⌠Can you post a file with one or two layers so I can see what it returns?
Of course, thanks. I have just created a blank file, with the name âdefaultâ translated in Chinese. The outcome is pretty much the sameChinese Layers - Test 01.3dm (45.7 KB)
Thanks.
Luca
Does the following work any better?
ExportLayerNamesCSV_Ex.py (453 Bytes)
Unfortunately I get the same error (from the same upload file).
Luca
Hmm, thatâs odd, I donât get any errors when I run it on your file and I get this .csv as a resultâŚ
test1.csv (11 Bytes)
However, if I open it in Notepad, I see this:
But in Excel I get this:
I guess I donât understand any of this encoding stuffâŚ
Edit - in Excel if I import the file via the Data menu instead of just opening it directly, I get this:
Many thanks!
Partially I now get similar results. I can open the csv correctly in Notepad and Notepad++ and I can see all the layers in order (with sublayers). However, when importing the csv in Excel from the DATA menu, I have to specify the character set and, trying different Chinese sets, the writing doesnât look correct. Which was did you choose? Was it automatic? I guess we are nearly there!
After all this work it could be nice to see it incorporated it as a standard feature in Rhino, if other users feel the need as well. Reversing the process would also be fantastic!
Luca
All working! so the secret was to select none.
Great, thanks very much!
Luca
One more thingâŚIf you create sublayers, is there any reason why the csv output has two colons created ( :: ) and, as consequence, in Excel I get an empty columns in the list, instead of adjacent columns? Thanks
Two colons is the Rhino standard format for the layer-sublayer separator. When you have a sublayer, Rhino outputs this automatically as part of the layer name. It could be changed by programming an extra line in the script to replace them with some other character/sequence.
When you import data in Excel, it sees the colons and somehow sets that up as a proposed separator. Thatâs why I had to manually choose âcommaâ as the separator above.
If you do change the sublayer separator output to something else, if you want to re-import your list, you would also need a custom conversion back to the double colon format to get the sublayers back.
Thanks, all clear.
Luca
