+1 saving layer states of worksession files (and linked blocks) would be really really helpful
the workaround I’m using right now is:
- copying linked blocks you want to change to a separate file
- making all necessary adjustments to layers
- saving the “layer state”
- saving that temporary file in a temporary location
- back in the original file importing layer state from that temporary file
- restoring that layer state when rhino starts
The last step can be automated by adding -LayerStateManager Restore $name-of-that-state
to Options–>General–>Command Lists (Run these commands every time Rhino starts)
I think this issue has been partially resolved. I did a test and Rhino remembers Visibility, Colour and Print Colour or referenced files. However the ability to change other parameters has now been blocked. For example when trying to change a Linetype parameter of a referenced layers, the following error pops out: Cannot change linetype of referenced layer.
I originally raised this issue 8 years ago, would be really useful to finally see it resolved.
This is really annoying to see that this is still blocked since so many years…
Please fix it ! Hard to collaborate on rhino without this type of features.
I just tested Rhino 8 and the issue still persists. Really disappointing, it’s been 9 years since I raised this issue…
