Is there a way to find input parameters connected to an output parameter of a Grasshopper component.
For input parameters, the IGH_Param have SourceCount and Sources but I can’t find the equivalent for output parameters.
jmv
jmv
In this video, I change the order of two inputs and two outputs.
And to update the connected input sources I just:
if (oldParam.SourceCount > 0) {
foreach (var src in oldParam.Sources)
newParam.AddSource (src);
I would like to reconnect the outputs.
Any idea is welcome.
IGH_Param.Recipients
Oh yes !
I had seen that but I did not understand its use and I had not even tried …
Thank you !
The thing is that changing the recipients does nothing, you have to change the sources of the recipient
if (oldP.Recipients.Count > 0) { for (var i = 0; i < oldP.Recipients.Count; i++) oldP.Recipients[i].AddSource (newP); }
