Would it be possible to implement a keystroke command for the popup menu ‘would you like to delete input object’ (Yes) (No) Maybe enter can stay as no, but shift + enter can be ‘yes’ or ‘y’ and ‘n’ could be used… it’s a lot of extra scrolling to click the box every time. When there are even more choices, I would like to be able to use the letter key for the first letter of the choice (as in ‘d’ for duplicate,etc)
This is already implemented. In Rhinoceros > Preferences > Legacy, check the “Always provide an input field for typed values” checkbox. If you are using single window modeling mode, in Rhinoceros > Preferences > Themes, check the “Always provide an input field for typed values” checkbox.
This allows you to use exactly the same typing shortcuts that exist in Rhino for Windows.
