Hi there,
I try to find the angle between two lines using the Angle component in grasshopper/Kangaroo2. However, as output the solver gives "KangaroosSolver.Goals.Angle2 instead of the desired angle.
How is this possible?
Best regards,
Simon
Hi there,
Best regards,
Simon
Hi @simonnpro
It sounds like you need the ‘Angle’ component found under the ‘Vector’ Tab in Grasshopper, not anything in Kangaroo.
