Hi, I have a surface and a polysurface, and when I call rs.JoinSurfaces() as below, the resulting object fails the IsObjectValid() check. When I join the same two surfaces interactively via _Join, the resulting object checks out ok. As you can see below, the input objects seems to be valid. Any idea what the problem could be?
Hi Josh
Just because input surfaces and polysurfaces are valid, does not mean they can join.
Did you try to join your geometry using a Rhino command? Does it work? Also, can you share the example with the surfaces?
I did try to join using the _Join rhino command. And yes it did work and produced a closed polysurface that is valid. So it seems like the _Join rhino command is producing a valid surface where as the python rs.JoinSurfaces() is producing an invalid surface. Any idea why _Join is succeeding where rs.JoinSurfaces() is failing?
I’ll work on getting a version of the surfaces I can post.
Thanks,
Josh
When I was preparing the 3dm file I figured out an answer. One of the surfaces that I was joining was created by revolving a planar open polycurve around the y axis. The problem was that a middle segment of the curve was along the y-axis. So the revolution created a single surface when in fact what I’d meant to create was two surfaces, one for either end segments of the polycurve. So the fix was to delete the segment along the y-axis, making the open polycurve into two curves, and revolving each separately to create the two surfaces.
Josh
