"Issue with Solid Fill in VisualARQ Clipping Plane in Rhino 8: How to Resolve
I’ve encountered an issue with the clipping plane feature in VisualARQ 3 in rhino 8 where the object fill is not displayed as expected.
Hi @uzairgulndm,
We are still working to support Rhino 8 section styles with VisualARQ objects so, if you need to fill VisualARQ objects sections you will need to do it using section attributes for now: https://youtu.be/QjE66xW-Vig?si=To6s2pnEcloeTYqd
thanks for the solution
Are you planning to include this in the VA3 release version?
Thanks!
Yes, we are currently working on that.
@Eugen @uzairgulndm we have just published the new VA3 Beta 5 version that includes the merge of R8 section styles with VA Sectio attributes. Your feedback is always welcome!
Section styles in the Properties panel:
Section styles in VA styles dialog:
thanks for sharing this
