@pascal you helped me with some scripts a few years ago. they were working fine then I got a new computer… seeing this message
help please thanks!
Hello- post the script, please.
Hello - as far as I can see this works here - how are you launching the script?
run python script command
I get that error above in my first post
Hello- that should work - does here - but doing it slightly differently here - try that.
Labeler.py (1.2 KB)
thank you !
what did you do? cus it’s happening to all my scripts…
Hello - make sure you are running the one that has these lines
textObj= rs.coercerhinoobject(X)
#textObj = sc.doc.Objects.Find(X)
I redownloaded the one you uploaded…
import scriptcontext as sc
import Rhino
def AveragePoints(aPts):
P = len(aPts)
X = Y = Z = 0
L = len(aPts)
for i in range(len(aPts)):
X = X + aPts[i].X
Y = Y + aPts[i].Y
Z = Z + aPts[i].Z
return Rhino.Geometry.Point3d(X/L, Y/L, Z/L)
def Labeler():
ids = rs.GetObjects("Select objects to label.", preselect=True)
if not ids:return
height = 1
if sc.sticky.has_key("LABEL_HEIGHT"):
height = sc.sticky["LABEL_HEIGHT"]
height = rs.GetReal("Set text height", height)
if not height: return
sc.sticky["LABEL_HEIGHT"] = height
for id in ids:
name = rs.ObjectName(id)
if not name:
continue
bb = rs.BoundingBox(id)
pt = AveragePoints(bb)
text = "%<objectname(" + chr(34) + str(id) + chr(34) + ")>%"
X = rs.AddText(" ", pt, height)
textObj.Geometry.TextFormula = text
sc.doc.Objects.Replace(X, textObj.Geometry)
sc.doc.Views.Redraw()
if __name__ == "__main__": Labeler()
