Issue with Brep/plane intersection and contour: nonplanar curve outputs
I am having weird results in a brep/plane intersection and with contour in GH.
I also tried contour (in Rhino) and got similar results: nonplanar curve outputs in the top and bottom:
Any ideas why this is happening?
Attached is a GH file with internalized geometry.
Info about the breps: they are generated form 2 curves (top and bottom) lofted.
Section.gh (22.2 KB)
a tolerance matter.
go to file properties units and use a tighter tolerance. recompute the gh definition after.
