Hello!
I’m working on a plug-in using C++ which will add leaders to a document. Everything is working perfectly when the number of leaders is low, but when the number of leaders gets higher (over roughly 1000), the text starts flickering on and off. I’m using a display conduit to show the leaders while you’re working in the file, then when I go to add the leaders to the document, many are missing the text, as shown in the attached image.
class LeaderConduit : public CRhinoDisplayConduit {
public:
std::vector<DLeader::Cluster>* t_clusters = nullptr;
LeaderConduit() : CRhinoDisplayConduit(CSupportChannels::SC_CALCBOUNDINGBOX | CSupportChannels::SC_PREDRAWOBJECTS) {
Enable();
bool ExecConduit(CRhinoDisplayPipeline& dp, UINT nChannel, bool& bTerminate) override;
bool DLeader::LeaderConduit::ExecConduit(CRhinoDisplayPipeline& dp, UINT nChannel, bool& bTerminate) {
UNREFERENCED_PARAMETER(bTerminate);
if (t_clusters == nullptr)
return false;
if (nChannel == CSupportChannels::SC_PREDRAWOBJECTS) {
for (DLeader::Cluster& c : *t_clusters) {
for (ON_Leader& l : c.GetLeaders(true)) {
CRhinoLeader n_leader;
n_leader.SetLeader(l);
n_leader.Draw(dp);
return true;
std::vector<DLeader::Cluster> DLeader::ClusterVect = std::vector<DLeader::Cluster>();
DLeader::LeaderConduit DLeader::GlobalConduit;
(I'm just using global variables for testing. The t_clusters pointer in the conduit is being set to the address of the above global vector.)
CRhinoCommand::result CCommandBakeLeaders::RunCommand(const CRhinoCommandContext& context) {
DLeader::BakeLeaders(context);
return CRhinoCommand::success;
void DLeader::BakeLeaders(const CRhinoCommandContext& a_context) {
for (DLeader::Cluster& c : ClusterVect) {
for (ON_Leader& l : c.GetLeaders()) {
CRhinoLeader* n_leader = new CRhinoLeader();
n_leader->SetLeader(l);
a_context.m_doc.AddObject(n_leader);
std::vector<ON_Leader> DLeader::Cluster::GetLeaders(const bool& a_update) {
if (a_update)
UncrossPoints();
std::vector<ON_Leader> r_vect;
for (Item& i : t_items)
r_vect.push_back(i.GetLeader());
return r_vect;
ON_Leader DLeader::Item::GetLeader() {
ON_Leader r_leader;
ON_TextContent* n_content = new ON_TextContent();
n_content->Create(stringToWchar(GetText()), ON::AnnotationType::Leader, currentDimStyle());
r_leader.SetText(n_content);
r_leader.SetPoints3d(3, GetLeaderPoints());
delete n_content;
return r_leader;
std::string DLeader::Item::GetText() {
if (t_textOverride)
return t_text;
return textFromId(t_id);
inline std::string textFromId(const ON_UUID& a_id) {
const CRhinoObject* n_object = objFromId(a_id);
if (!n_object)
return "NULL";
const CRhinoPointObject* n_pointObj = CRhinoPointObject::Cast(n_object);
if (n_pointObj) {
ON_3dPoint n_point = n_pointObj->Point().point;
return std::to_string(n_point.x) + ", " + std::to_string(n_point.y);
return "NULL";
inline const CRhinoObject* objFromId(const ON_UUID& a_id) {
unsigned int n_serialNumber = RhinoApp().ActiveDoc()->RuntimeSerialNumber();
return CRhinoObject::FromId(n_serialNumber, a_id);
inline const ON_DimStyle* currentDimStyle() {
return &RhinoApp().ActiveDoc()->DimStyleContext().CurrentDimStyle();
If I’m doing anything horrible please let me know. Is there a different way I should be using the display conduit? Or is over 1000 items just too much to display in this way? I was also having trouble getting the style of the leaders to match the selected annotation style of the document, thus the bandaid solution in currentDimStyle(). Is there a resource on a better way to do this and get it to work in the display conduit? I was hoping to make them red and green, similar to the style of grasshopper.
Thank you!
Dru
