Hello all, this bug has been happening for a while apparently but it still hasn’t been resolved in Rhino Inside Revit 1.15.8522.
None of the energy plus components can be used with Revit at the monent. I know about the set_python_path.bat that could fix the problem but it didn’t help me. I tried to reinstall Ladybug 1.6 from Revit directly but also no luck there.
Solution exception:
Failed to import ladybug:
No module named _sqlite3
The only think i can gather is that _sqlite3 isn’t being loaded, which could be a conflict with other Revit Add-in, when the addins load the first to load wins. Is there a pollination revit plugin loading as well?
It works in 2022 but not in 2023. I will definitely post on their forums but that 2022 2023 difference is still peculiar, have you tried the same thing in 2022 ?
Thanks for trying to answer this, @Japhy . Ladybug Tools has full support for the Rhino Inside environment but you have to set it up correctly and avoid the conflicts between the version of IronPython that Revit uses and the one that Rhino uses.
The reason why you get all of the components turning red has to do with the fact that Rhino has structured the Inside ecosystem such that each and every “Inside” environment has it’s own IronPython search paths. So, whenever you start using a new environment, you need to re-run the set_python_path.bat as I note here:
For the issue with the sqlite3 module, I’m nearly positive that this has to do with the Revit IronPython interfering with the Rhino IronPython. Hopefully, someone else on the McNeel team could shine some light here but I know that there have been many cases in the past where Autodesk’s IronPython conflicts with Rhino and a quick search will reveal this:
Hello, I had the exact same Issue with Rhino Inside Revit not finding _sqlite3.
I’ve found an additional solution that did work for my by uninstalling a Revit plugin/add-on that was also working with Python and Ironpython, see my post here:
