There is a rhino 4 script that I am trying to convert to rhino 5 vb.net.
The only thing I am missing is ispointinsurface.
The script has to delete all points that are not in the surface.
So only the underlying points need to stay.
The excisting script part is:
For i=0 To UBound(allpointsinfile)
Dim pointcoords = Rhino.pointcoordinates(allpointsinfile(i))
If Not Rhino.ispointinsurface(surface, pointcoords ) Then
Rhino.deleteobject allpointsinfile(i)
End If
Next
and what i got is:
Dim objref As Rhino.DocObjects.ObjRef() = Nothing
Dim vb = Rhino.Input.RhinoGet.GetMultipleObjects(“PointSelected”, False, DocObjects.ObjectType.Point, objref)
If vb <> Rhino.Commands.Result.Success Then
Return vb
End If
For Each obj In objref
doc.Objects.UnselectAll()
doc.Objects.Select(objref(i))
If Not (ISOBJECTINSURFACE) Then
doc.Objects.Delete(objref(i), True)
i = i + 1
End If
Dim go = New GetObject()
go.SetCommandPrompt("Select closed surface or polysurface")
go.GeometryFilter = ObjectType.Surface Or ObjectType.Brep
go.GeometryAttributeFilter = GeometryAttributeFilter.ClosedSurface Or GeometryAttributeFilter.ClosedPolysrf
go.Get()
If go.CommandResult() <> Result.Success Then
Return go.CommandResult()
End If
Dim brep As Brep = go.Object(0).Brep()
If brep Is Nothing Then
Return Result.Failure
End If
Dim refs As ObjRef() = Nothing
Dim rc As Result = Rhino.Input.RhinoGet.GetMultipleObjects("Select test points", False, DocObjects.ObjectType.Point, refs)
If rc <> Result.Success Then
Return rc
End If
Dim tol As Double = doc.ModelAbsoluteTolerance
For Each ref As ObjRef In refs
Dim pt As Point = ref.Point()
If pt IsNot Nothing Then
If brep.IsPointInside(pt.Location, tol, True) Then
doc.Objects.Select(ref)
End If
End If
Next
doc.Views.Redraw()
Works perfect. Had to change some things because my vb2010 did not recognize Brep only so needed Rhino.DocObjects.Brep same with GeometryAttributeFilter etc.
P.S. Why would you use:
Dim go = New GetObject() go.SetCommandPrompt(“Select closed surface or
polysurface”) go.GeometryFilter = ObjectType.Surface Or
ObjectType.Brep go.GeometryAttributeFilter =
GeometryAttributeFilter.ClosedPolysrf go.Get() If go.CommandResult()
<> Result.Success Then Return go.CommandResult() End If
in stead of:
Dim mesh_point2 = Rhino.Input.RhinoGet.GetMultipleObjects(“PointSelected”, False,
If mesh_point2 <> Rhino.Commands.Result.Success Then
Return mesh_point2
End If
