I want to extrude a surface from an open curve to meet an irregular existing surface. Can I do this in Rhino?
Thanks-
Thanks-
Hal9000
It is always helpful if you put the file your working on when asking a question. From what your asking this should be no problem.
All my best … Danny
If I understand you correctly, you can select the curve and from the menu Surface/Extrude/ Straight or Tapered .etc
This will make a surface.
You can check the surface normals with dir to make sure the outside is on the outside, before joining or doing other things with it.
I think what you are looking for is ExtrudeCrv with the ToBoundary option. The Boss command is for creating polysurfaces from closed curves and surface input.
Or if you want a tapered surface ues ExtrudeCrvTapered with the ToBoundary option.
Or you can over-extrude the surface and trim it back to your irregular one.
