Is Mesh still single precision?
I think I heard Mesh is rewritten from scratch and now vertices are double precision. But seems like Rhino.Geometry.Mesh is still single precision (but I do see NGons…) Is there a new mesh class supports double precision or is it postponed to Rhino 7?
I had a small house modeled by a mesh and it’s origin was set to somewere in the atlantic ocean…
In Rhino 6 there is the UseDoublePrecision toggle on the Mesh.Vertices object. See also
Thanks Menno! This is helpful!
[Memo]Probably I was only one who doesn’t know but I think leaving some notes is helpful…
Mesh.Vertices always returns Point3f.
But you can get a Point3d by Mesh.Vertices.Point3dAt()
Mesh.Vertices.Add() now accepts both Point3f/Point3d
Mesh.Vertices.SetVertex() now accepts both Point3f/Point3d
foreach(var P in mesh.Vertices) loops over Point3f.
[edit: this statement is wrong] But you can still call foreach(Point3d P in mesh.Vertices) which loops over Point3d.
Don’t forget to set UseDoublePrecision true.
Unfortunately this is a misunderstanding, you would get a single precision vertex in double-precision format, because of implicit casting of Point3f to Point3d. Any enumeration of mesh.Vertices will give single precision Point3f values!!
You’re safest if you use mesh.Vertices.To3dPointArray() and iterate that.
Agh… Yes, I actually wondered how it works…
Sorry for the misleading post…
Hi.
I’m struggling with this. Can someone please give a step-by-step to how this is enabled?
Does this help:
