Are you able to achieve the shape and structure you are looking for using Rhino’s Rebuild command? If so, then you can do what this command does in RhinoCommon using the Rhino.Geometry.Curve.Rebuild function.
Hi dale,
I hope to rebuild curve within a specific tolerance value.
How can I give tolerance when using Rhino.Geometry.Curve.Rebuild (or Rebuild command) ?
In NetworkSrf command, We give specify tolerance (edge, and inner curve), Rhino does create smooth nurbs surface . Hopefully, I could do in nurbs curve as same as that.
