hello,
i have a problem, i need to get the intersecting points on several curves.
i took the curves put it into a curve component, intersect them, boom works brilliant.
so now i dont want to get intersections if the lines are allined. the plan is to create a line with the line component out of two points on the curve. i get the points from a evaluate curve component. so i have lines, when i put the lines in the intersection component (which works with crvs) theres no output. i tried to graft the line component, or put the line into a crv component but nothing helps.
somebody has any ideas?
