Intersect Curve and Mesh
Might be a simple question but how do you find the intersection between a mesh and a curve in Rhino. I’m aware of the Mesh Curve Intersection component in Grasshopper (MCX) but I am looking for the equivalent in Rhino. The intersection should be where the arrow is in the screenshot.
Mesh Curve Intersection.3dm (1.8 MB)
Hi Mike -
That’s an old wish, yes - RH-4221.
FWIW, I tend to visually identify the region where the line intersects, duplicate the mesh faces in that area, and convert those to NURBS planes.
Yeah, oddly enough that does not seem to be directly exposed in Rhino currently. I was surprised, I thought MeshIntersect would cover that case.
Here is a quickie Python script that will allow you do that. Note that the Curve/Mesh intersector does not create lines if there are curves that actually overlap mesh faces - simply points at the end of each overlap. Also, internally (as with the GH component, which uses the same underlying code) NURBS curves are converted to polylines for the intersection - as there is no NURBS curve/Mesh intersect method.
CrvMeshIntersection.py (1.1 KB)
Hey, 2026 here, and intersecting meshes and curves is still not a thing in Rhino.
Also, I’ve been advocating a UNIVERSAL intersect tool. All the arguments I heard about why you need a “MeshIntersect” are frivolous,
Come on guys…
