Hello, I have a beginner question about the Interpolate curve component. I simply want to interpolate two curves through two separate lists of points. The only way I know how to that is by using two Interpolate components, one for each list. Is there a way to manage both lists so I can get the same result by having both lists connected to one component ? Thanks!
you can just plug your two set of points in the interpolate curve component. Since its already into separated lists. just press shift while you’re connecting the second set of point to the component.
hi,
Thomas is right, but he forgot to mention one thing.
If you feed both sets of points into the interpolate component you’ll get a single curve that goes through all of them.
Try feeding them into entwine which you then feed into interpolate in order to get two curves.
Doing that makes a flat merged list.
The way to do this is entwine
At the same time
Amazing, thanks a lot for the help!
