I am trying to integrate Xunit framework with Grasshopper plug in in order to write unit test cases . But my test cases are getting failed giving exception
System.DllNotFoundException : Unable to load DLL ‘rhcommon_c’: The specified module could not be found. (Exception from HRESULT: 0x8007007E)
I have installed rhinoInside in the main project and added that project as a reference to my test project . All the packages from main project are successfully visible in my test project, still getting same exception .
rhcommon_c dll is a part of Rhino exe , but test project should not be dependent on the Rhino as , unit test project should be independent.
Most of the test cases runs but few test cases are getting failed everytime. Fer test cases are running some time , and getting failed some time giving same exception . I have attached a screenshot with this .
