This appears to be a problem in both Rhino 5 and 6 - Attributes-Attached User Text is missing - this same data is present in the InstanceDefinition.Objects() Attributes properties.
To reproduce, make a box, assign it attributes user text, make it into a block, and run the following C# script in grasshopper:
private void RunScript(object x, object y, ref object A, ref object B)
Rhino.DocObjects.InstanceObject block = RhinoDocument.Objects.OfType<Rhino.DocObjects.InstanceObject>().First();
RhinoObject[] objs;
ObjectAttributes[] atts;
Transform[] xforms;
block.Explode(true, out objs, out atts, out xforms);
A = atts.SelectMany(a => a.GetUserStrings().AllKeys);
B = block.InstanceDefinition.GetObjects().SelectMany(o => o.Attributes.GetUserStrings().AllKeys);
You’ll see that the A output is empty, while the B output has the specified user string keys.
