InstanceDefinition UserDictionary
I’m trying to do this:
  1. User clicks a button in a panel.
  2. Get the selected Block.
  3. Set a key on the BlockDefinition:
if (myInstanceObject.InstanceDefinition.UserDictionary.SetKey("mykey", 42)) {
    // tried both with, and without myInstanceObject.CommitChanges(); here.
This succeeds. I get true back, and if I try to read the value immediately after, it’s correct (42).
  1. In a DisplayConduit I read the value back with:
if (myInstanceObject.InstanceDefinition.UserDictionary.TryGetInteger("mykey", out int itemId)) {
  // Draw textdot here with `itemId`
This fails. There is nothing there.
Am I at all allowed to set UserDict on InstanceDefinitions? If so, how do I “commit” the changes, so they are available everywhere?
Shamelessly tagging you @dale as you are usually really good at answering my silly questions.
Hi @aske,
This script seems to work:
import Rhino
import scriptcontext as sc
import System
__rnd__ = System.Random(System.Environment.TickCount)
def test_idef_setvalue(iref_obj, key, value):
    if isinstance(iref_obj, Rhino.DocObjects.InstanceObject):
        rc = iref_obj.InstanceDefinition.UserDictionary.Set(key, value)
        if rc:
            print("Dictionary set, value = {0}".format(value))
def test_idef_getvalue(iref_obj, key):
        rc, value = iref_obj.InstanceDefinition.UserDictionary.TryGetInteger(key)
        if rc and value:
            print("Dictionary get, value = {0}".format(value))
def testme():
    filter = Rhino.DocObjects.ObjectType.InstanceReference
    rc, objref = Rhino.Input.RhinoGet.GetOneObject("Select block", False, filter)
    if not objref or rc != Rhino.Commands.Result.Success:
        return rc
    obj = objref.Object()
    key = "test"
    value = __rnd__.Next(1000)
    test_idef_setvalue(obj, key, value)
    test_idef_getvalue(obj, key)
if __name__ == "__main__":
    testme()
I see your key had different cases (“mykey” vs “myKey”). Perhaps this is the issue?
– Dale
Sorry, I should have been more clear: It’s RhinoCommon.
edit: and the key is just a placeholder. It’s the same in the real code.
The button is in a Eto panel.
But overall it should work, is what I’m getting from you?
Do I need to commit, or something else?
I spent some time creating a minimal repro case from the Rhino Eto Samples.
However it works fine in the sample I have created, and I literally just copied code around :man_shrugging:
I did narrow down the issue to something really weird in our project though: The key is put into a centralized constants file as public const string. This works in the sample project. But in the full project it doesn’t work.
Here is a video of the behavior:
https://stykka-public.s3.eu-west-1.amazonaws.com/tmp/weird_behavior.mov
The video shows Visual Studio, compilation to Rhino, and demonstration of working and none-working code:
00:14 For all blocks, all blockdefs keys are displayed in a display conduit in a TextDot.
00:18 In a Panel (Stykka → Templates) there is a button that triggers the code.
00:21-00:27 When clicking the “Set for current button” button the TextDot text does not update.
00:34 Code is displayed that uses the constant string.
		        // This fails!
				reloadedInstanceObject.InstanceDefinition.UserDictionary.Set(Constants.USER_KEY_ITEM_TEMPLATE_ID, item.id);
00:36 Code is changed to using the same string, but typed in place.
		        // This works!
				reloadedInstanceObject.InstanceDefinition.UserDictionary.Set("com.stykka.part.item_template.id", item.id);
00:43 Compile and run.
01:33 Same button as before now works.
01:52 Constant is shown.
I’m not a C# expert. Am I declaring the constants wrong? It works in the smaller sample project.
namespace Stykka.Common.Utils
    public static class Constants
        public const string USER_KEY_ITEM_TEMPLATE_ID = "com.stykka.item_template.id";
I don’t really know what to do from here, other than hardcoding the strings :sob:
Hi @aske,
The video isn’t helpful. And without code I can run here, I can only speculate.
But if your conduit is holding onto an instance of InstanceDefinition and somewhere in your plug-in you add user text to it, then your conduit is going to need to re-get the instance definition as it is now holding onto an old version.
My wild guess…
– Dale
I put up the modified Eto sample project here: Set and Display int on Block defs via EtoPanel and DisplayConduit. · Doerge/rhino-developer-samples@beb34e5 · GitHub
To be clear: This works’ish. There is sometimes some issues with the TextDot not displaying immediately. You either have to click the “Set” button a few times, or move the Blocks around a bit.
I think I’ve been careful to always use the Guids and always call into Rhino to get a reference to the instancedef’s, but maybe you can spot my mistake.
Thanks for taking a look!
@dale did you have time to look at my sample? Could you spot any mistakes?
Not really. Can you post the project?
– Dale
I’m not sure I understand your question. The diff I linked to previously is in a forked McNeel project:
Or do you mean my “real” project? I attempted to split it out of there, to make it easier to see what’s going on.
