Hello Jim and Armin,
I am “hearing” you. I think a significant part of my mindset in configuring a new machine was being governed by continuing along a path of a “traditional” workstation set-up. I believe that I am learning - from your help- and others that the hardware is changing so dramatically that so does your approach need to do likewise. I am still a little leery of moving to some “gaming” hardware but it seems like I am moving in a different direction with the configuration set-up I started this thread with.
Jim- I am certainly looking into having dedicated “display” and “compute only” cards.
For the monitors, I got the 2 Eizo FlexScan S2133 years ago when it was finally time to retire my 21 inch CRT monitor and planned to add a 3rd FlexScan now.
Way back then on the more rectangular shaped flat panel monitors I could see a slight skewing of the letters of text. This really bothered me and of quite importance this distortion of the text made it impossible to have really nicely crafted typography. For example, you cannot do kerning. The monitor expert agreed, the aspect ratio on these more rectangular monitors were to far form being square. Thus, the FlexScan monitors with a much closer to square aspect ratio, tilt to a portrait orientation that is great for document reading and creating and I think quite nice image quality. They have been wonderful. I had no idea how much GPU resource they use and I was just going on another “rule of thumb”, that as I remember, calls for 4 GB of GPU memory per monitor. Now, gee- 12 ish years later this text distortion might no longer be an issue ? So maybe a different monitor is in play to ? The FlexScans can easily be put to good use elsewhere.
Jim- As you indicate "…
Yes, indeed, Brenda suggests:
Although I do not yet understand the technical issues she writes of.
Armin-
That’s a big part of the “rub” Ideally, I do not want trade offs, I want my cake and eat it to. But perhaps the technology is just not at that point yet.
Only a fool argues with the truth. But you are getting at a cyclic issue. I get a new computer system that allows me to work effectively on the projects “of the day”. However, over not to much time passage, the projects and I change. Additionally, I become out of date with respect to computer hardware. And it is only when I can no longer do what I want to do and the efficiency with that I can work [and to an extent the quality of the work degrades- because there is now a difference between what I am doing and what I could do.] do I start the process anew of learning the attributes of the latest computer technologies [and now maybe also computer monitor technology] and then matching these to what I need for what I want / am doing.
But I do try to do my “homework” and get as far along as I can on my own before enlisting others and having as best an idea of what I will need. And if I am wrong well then I am in a pretty good position to learn. Another words; others and you are [I sincerely hope] not at all wasting your time in helping me because I am in a position to learn. Even if I am not so quick to get it, I do usually, finally get it, without needing an exorbitant amount of time to do so. I imagine others reading this tread will learn to.
Thank you,
Andy
