Installing a .yak plugin for all users on a machine
Hi there!
I’m about to publish a plugin inside a local network over admin and we are looking for a way to install it for all users on the machine.
The plugin is packaged as .yak and I initially though that we can install it via the yak.exe in “%ProgramFiles%\Rhino 8\System\Yak.exe" - but it turns out that installs the plugin always in “%USERPROFILE%\AppData\Roaming\McNeel\Rhinoceros\packages\8.0” of the user running yak.exe and there seems to be no command to run execute it for all users
Is there a good way to do this?
Does a plugin path directory exist which is not in the user profiles?
Also I like that yak properly registers the plugins - would be great to keep that.
I have already created an installer as well for users, but ideally we would like to have all users in the network have the plugin just “naturally” be in their UI
Does anyone has experience with this and can help eventually
Thanks already,
Cheers
Chris
