It seems that Jakinta has already provided you with a solution to the same situation in your another topic… Why do you keep repeating similar questions? Did you understand his solution?
I understand you comment
Yes, the solution of Jakinta did work and yes I do understand .
However I would like to keep the script as short as possible. And just came with an Idea of a very short solution:
After the lists are added together (as in this question). I can simply use the ‘Mass addition’ command, to generate the consecutive points.
Besides I am honestly open to learn and think that this list manupulation would be very helpfull, also in other parts.
Thank you again
