Hello to all
Is there an example (*.cs file or *.sln) in this field toinsert input parameter indefinitely in the plug-in component?(similar SortList Component)I did not find anythingb in grasshopper3d and mcneel forums
@Mahdiyar
using Grasshopper.Kernel;
using Grasshopper.Kernel.Parameters;
using System;
namespace UselessPlugin
public class UselessComponent : GH_Component, IGH_VariableParameterComponent
public UselessComponent() : base("Useless", "Useless", "Useless", "Useless", "Useless") {}
protected override void RegisterInputParams(GH_InputParamManager pManager)
pManager.AddGenericParameter("A", "A", "A", GH_ParamAccess.item);
pManager[0].MutableNickName = false;
pManager[0].Optional = true;
protected override void RegisterOutputParams(GH_OutputParamManager pManager)
protected override void SolveInstance(IGH_DataAccess da){}
protected override System.Drawing.Bitmap Icon => null;
public override Guid ComponentGuid => new Guid("9F91A1A6-F2B4-41E4-AB58-E8DF74BCB438");
public bool CanInsertParameter(GH_ParameterSide side, int index) => side != GH_ParameterSide.Output && index != 0;
public bool CanRemoveParameter(GH_ParameterSide side, int index) => side != GH_ParameterSide.Output && index != 0;
public IGH_Param CreateParameter(GH_ParameterSide side, int index)
var name = GH_ComponentParamServer.InventUniqueNickname("ABCDEFGHIJKLMNOPQRSTUVWXYZ", Params.Input);
Params.RegisterOutputParam(new Param_GenericObject {Name = name, NickName = name, Description = name, Access = GH_ParamAccess.item}, index);
return new Param_GenericObject {Name = name, NickName = name, Description = name, MutableNickName = false, Optional = true, Access = GH_ParamAccess.item };
public bool DestroyParameter(GH_ParameterSide side, int index)
Params.UnregisterOutputParameter(Params.Output[index]);
return true;
public void VariableParameterMaintenance() {}
How do I need to write using Python? It keeps reminding me that my pManager does not have the AddGenericParameter method
Here they are:
GH_Component.GH_InputParamManager.AddGenericParameter
GH_Component.GH_OutputParamManager.AddGenericParameter
– Dale
I tried, but why can’t I call the methods inside GhPython?
