I am creating some geometry based on user inputs and I’m creating a JSON object from all information which the geometry generation needs. This works ok in a local env in GH but I am not sure how to implement it to Shapediver?
The JSON object is already created by an algorithm which will come from a front-end app, a ReactJS app. I could also save this object or file in a cloud storage, with an URI. The file will be frequently updated by user interaction and I would also like to update the Shapediver model.
What would be the best way to achieve this?
PS.: I would be also fine if I could call the Shapediver back-end API and feed my object there.
ok, getting there. I am using this component and you may see in my screenshot above that it works also from a remote URI. …I also uploaded this definition to SD and looks like this:
So then the question goes down to, is it possible to query a parameter change on this JSON file with the API? Or even, may I pass in a JSON object as value to a parameter?
