Is it possible with standard Grasshopper without using Anemone addon or Data recorder?
I just learned this today!
The following python script should do it:
if "count" not in globals():
count = 0
if input1:
count += 1
If input2:
count -= 1
I dont know python. Is it possible with standard widgets?
Insert a python component.
Double click it to open the editor.
Delete whatever is there.
Copy the following code in.
Click okay to save and close.
count = 0
if x:
count += 1
If y:
count -= 1
a = count
Now you have a component that outputs a number. Whenever you press a button connected to x the number will go up and down on y.
The “if” before y should be lowercase. Sorry about that
thanks you! Can you please another button which will decrease the number?
Just connect a button to the y input
Hi!
Very nice!
The only thing I noticed is: when this Python component is present in a ‘Cluster’, everytime the cluster is reopend, the numbering is reset to 1.
Do you know a solution to ‘remember’ the last number?
Many thanks
