In search Of WoodLandCreatures in a Custom User Data List
I am trying to get Custom User Data to work and be saved correctly.
Everything seems to works but is not saved to a new file. I am using Visual Studio to debug and it is bringing up a new document. After running the WoodLandCreatures command there seems to be a lot of traffic calling the PhysicalData class attached to each text object.
  • OnClick of the text
  • OnClick of the view
  • OnClick of any of the tabs
This plus the save problem makes me think I have something setup incorrectly. I have attached the detail listing in the document created by VS and the one that I saved. The relevant part is this I think. Before the save in debug mode this is in the detail for the text. In the saved document it is missing:
UserData ID: 71FD438F-BB37-4a05-A1BE-11D3E1912079
Plug-in: Simple List
description: Physical Properties
saved in file: yes
copy count: 1
Sorry for the long-winded post but I am hoping it will help someone spot the error.
Thanks for any help.
Best;
Steve
I have got the following code limping along so far:
The PhusicalData Class (Thanks Rhino Support):
using System;
using System.Collections.Generic;
using Rhino;
using System.Runtime.InteropServices;
namespace AsaSimpleList.Model
    [Guid("71fd438f-bb37-4a05-a1be-11d3e1912079")]
    public class PhysicalData : Rhino.DocObjects.Custom.UserData
        public int Weight { get; set; }
        public double Density { get; set; }
        public List<String> MyList { get; set; }
        public PhysicalData()
            RhinoApp.WriteLine("public PhysicalData()");
        public PhysicalData(int weight, double density, List<String> myList)
            Weight = weight;
            Density = density;
            MyList = myList;
        public override string Description => "Physical Properties";
        public override bool ShouldWrite => true;
        public override string ToString()
            return $"weight={Weight}, density={Density}";
        protected override void OnDuplicate(Rhino.DocObjects.Custom.UserData source)
            PhysicalData src = source as PhysicalData;
            if (src != null)
                Weight = src.Weight;
                Density = src.Density;
                MyList = src.MyList;
        protected override bool Read(Rhino.FileIO.BinaryArchiveReader archive)
            Rhino.Collections.ArchivableDictionary dict = archive.ReadDictionary();
            if (
                dict.ContainsKey("Weight")
                && dict.ContainsKey("Density")
                && dict.ContainsKey("ListKey"))
                Weight = (int) dict["Weight"];
                Density = (double) dict["Density"];
                MyList = (List<string>) dict["ListKey"];
            return true;
        protected override bool Write(Rhino.FileIO.BinaryArchiveWriter archive)
            var dict = new Rhino.Collections.ArchivableDictionary(1, "Physical");
            dict.Set("Weight", Weight);
            dict.Set("Density", Density);
            dict.Set("ListKey", MyList);
            return true;
The calling command:
using System;
using AsaSimpleList.Model;
using Rhino;
using Rhino.Commands;
using Rhino.DocObjects;
using Rhino.Geometry;
namespace AsaSimpleList.Commands
    public class WoodLandCreatures : Command
        static WoodLandCreatures _instance;
        public WoodLandCreatures()
            _instance = this;
        ///<summary>The only instance of the WoodLandCreatures  command.</summary>
        public static WoodLandCreatures Instance
            get { return _instance; }
        public override string EnglishName
            get { return "WoodLandCreatures"; }
            //Crate text entity
            TextEntity entity = TextEntity.CreateWithRichText(
                "Chipmunk"
                , doc.Views.ActiveView.ActiveViewport.ConstructionPlane()
                , doc.DimStyles.Current
                , false
                , 0
                , 0
            //Create Attribute then add the current layer to the LayerIndex property
            ObjectAttributes entityAttributes = new ObjectAttributes();
            entityAttributes.LayerIndex = doc.Layers.CurrentLayerIndex;
            //Call public PhysicalData(int weight, double density, List<String> myList)
            //Call public List<String> MyList { get; set; }
            PhysicalData physicalData = new PhysicalData(33, 4, new List<String>()
                    "Bear",
                    "Chipmunk",
                    "Squirrel",
                    "Skunk",
                    "Deer",
                    "Woodpecker",
                    "Owl",
                    "Mouse",
                    "Fox",
                    "Moose",
                    "Hedgehog",
                    "Raccoon",
                    "Rabbit",
                    "Badger",
                    "Philippine eagle",
            //Call public override string Description => "Physical Properties";
            entityAttributes.UserData.Add(physicalData);
            //Create and add entity to current view and plane
            //Call public PhysicalData()
            //Call protected override void OnDuplicate(Rhino.DocObjects.Custom.UserData source)
            //Calls  public int Weight { get; set; }, public double Density { get; set; }, public List<String> MyList { get; set; }
            Guid entityGuid = doc.Objects.AddText(entity, entityAttributes);
            //Find the text object using the guid
            RhinoObject ro = doc.Objects.FindId(entityGuid);
            //Get the physical data class that was created and applied to the attributes of the text
            var objectUserData = ro.Attributes.UserData.Find(typeof(PhysicalData)) as PhysicalData;
            //Call public double Density { get; set; }
            RhinoApp.WriteLine(objectUserData.Density.ToString());
            //Call public int Weight { get; set; }
            RhinoApp.WriteLine(objectUserData.Weight.ToString());
            //All creatures are listed
            foreach (String item in objectUserData.MyList)
                RhinoApp.WriteLine(item);
            //On each click of of Text, Properties, view
            //Call public override bool ShouldWrite => true;
            //Call protected override bool Write(Rhino.FileIO.BinaryArchiveWriter archive)
            //On Save As
            //        public override bool ShouldWrite => true;
            //        protected override bool Write(Rhino.FileIO.BinaryArchiveWriter archive)
            return Rhino.Commands.Result.Success;
Befor the save:
text
Object name: (not named)
Layer name: Default
Render Material:
source = from layer
index = -1
Attribute UserData:
UserData ID: 563238F9-C201-411d-A7B1-13895A0317AD
Plug-in: Rhino
description: AutoPointsOn
saved in file: no
copy count: 1
saved in file: yes
copy count: 1
Geometry:
Text
(ON_Text)
Point: (0,1.27844,0) X-axis: (1,0,0) Y-axis: (0,1,0)
Height: 0.12500 inches
Wrapping width not set.
Justification: left,top
Runs: 1
Run 0: - Font: Arial
Text : Chipmunk
Not wrapped
  Annotation style:
    Style index: 0
    Style id: BFF1D85E-72AC-4226-884A-872A8473132C
    Text height: 0.12500 inches
    Model space scale: 10
    Scaled text height: 1.25000 inches
    Arrow type:   Solid triangle
After the save:
text
Layer name: Default
Render Material:
source = from layer
index = -1
Attribute UserData:
Plug-in: Rhino
saved in file: no
copy count: 1
Geometry:
Text
(ON_Text)
Runs: 1
Text : Chipmunk
Not wrapped
  Annotation style:
    Style index: 0
Quickly fixed code markup for you (enclose code in tripple backticks).
Thanks Nathan! A lot easier to read.
Best;
Steve
Thanks to Rhino Support for all the help in getting this to work. The following code seems to be working but not production ready and only a sample.
Adding User Data to each object or objects attributes will be a performance hit on large files so as with most things, moderation may be wise. I have noted in the code blocks the traffic patterns I see in using this class.
Please let me know if you see any issues that may be a problem.
Thanks again
Steve
Root Sample: Info: RhinoCommon object plug-in user data [McNeel Wiki]
post by: lando.schumpich
UserData Class:
    public class SimpleListData : Rhino.DocObjects.Custom.UserData
        private Guid ClassId = Guid.NewGuid();
        //Your User Data class must have a public parameter-less constructor
        //Each time an object with User Data is selected a new SimpleListData class is instantiated and filled using OnDuplicate
        public SimpleListData()
        public ArchivableDictionary WoodlandCreatures { get; set; }
        public string[] Birds { get; set; }
            get { return "WoodLand Creatures"; }
            StringBuilder stringBuilder = new StringBuilder();
            foreach (var valuePair in WoodlandCreatures)
                stringBuilder.AppendFormat($"Key: {valuePair.Key}, Value: {valuePair.Value} :");
            foreach (var b in Birds)
                stringBuilder.AppendFormat($"Bird: {b}");
            return stringBuilder.ToString();
        //On each object move the custom user data is moved back into the new instance
            SimpleListData src = source as SimpleListData;
            if (src != null)
                WoodlandCreatures = src.WoodlandCreatures;
                Birds = src.Birds;
        //Validation for each object during write to file.
            get
                if (WoodlandCreatures.Count == 15)
                    return true;
                if (Birds.Length == 2)
                    return true;
                return false;
        //Read from file
            //Validation on read for each object assigned this user data object and guid
            Rhino.Collections.ArchivableDictionary creatures = archive.ReadDictionary();
            string[] birds = archive.ReadStringArray();
            if (creatures.Count == 15)
                WoodlandCreatures = creatures;
            if (birds.Length == 2)
                Birds = birds;
            return true;
        //Write to file
            archive.WriteDictionary(WoodlandCreatures);
            archive.WriteStringArray(Birds);
            return true;
Calling code:
    [Guid("8808a28f-fa84-4c25-a8df-44be72f1f22f")]
    public class WoodLandCreatures : Rhino.Commands.Command
        protected override Rhino.Commands.Result RunCommand(RhinoDoc doc, Rhino.Commands.RunMode mode)
            SimpleListData simpleListData = null;
            //If User Data has been attached to selected objects write to command history.
            IEnumerable<RhinoObject> test = doc.Objects.GetSelectedObjects(false, false);
            foreach (RhinoObject ro in test)
                simpleListData = ro.Geometry.UserData.Find(typeof(SimpleListData)) as SimpleListData;
                if (simpleListData != null)
                    //Write the WoodLand Creatures
                    RhinoApp.WriteLine(simpleListData.ToString());
            //Write a woodland creature name to the viewport each time through
            Plane activePlane = doc.Views.ActiveView.ActiveViewport.ConstructionPlane();
            Point3d origin = activePlane.Origin;
            Random rnd = new Random();
            origin.Y = origin.Y + rnd.Next(20);
            activePlane.Origin = origin;
            //Crate text entity
            var entity = TextEntity.CreateWithRichText(
                "Chipmunk"
                , activePlane
                , false
                , 0
                , 0
            //Add the text and return the guid then use the guid to find the object.
            Guid entityGuid = doc.Objects.AddText(entity);
            doc.Views.Redraw();
            RhinoObject obj = doc.Objects.FindId(entityGuid);
            //Take a look at the object just created to se if there is User data. Should always be false.
            simpleListData = obj.Geometry.UserData.Find(typeof(SimpleListData)) as SimpleListData;
            if (simpleListData == null)
                ArchivableDictionary activeDirectory = new ArchivableDictionary(1, "Physical");
                activeDirectory.Set("WoodLandCreature01", "Bear");
                activeDirectory.Set("WoodLandCreature02", "Chipmunk");
                activeDirectory.Set("WoodLandCreature03", "Squirrel");
                activeDirectory.Set("WoodLandCreature04", "Skunk");
                activeDirectory.Set("WoodLandCreature05", "Deer");
                activeDirectory.Set("WoodLandCreature06", "Woodpecker");
                activeDirectory.Set("WoodLandCreature07", "Owl");
                activeDirectory.Set("WoodLandCreature08", "Mouse");
                activeDirectory.Set("WoodLandCreature09", "Fox");
                activeDirectory.Set("WoodLandCreature10", "Moose");
                activeDirectory.Set("WoodLandCreature11", "Hedgehog");
                activeDirectory.Set("WoodLandCreature12", "Raccoon");
                activeDirectory.Set("WoodLandCreature13", "Rabbit");
                activeDirectory.Set("WoodLandCreature14", "Badger");
                activeDirectory.Set("WoodLandCreature15", "Philippine eagle");
                simpleListData = new SimpleListData();
                //Save the WoodLand Creatures
                simpleListData.WoodlandCreatures = activeDirectory;
                //Save two birds to an array
                simpleListData.Birds =  new string[] {"Black-footed Laysan", "Short-tailed Anhinga"};
                //Add user data to the object
                obj.Geometry.UserData.Add(simpleListData);
            else
                //RhinoApp.WriteLine("{0} = {1}", simpleListData.Description, simpleListData);
