Importing STL or STEP file directly into grasshopper
Hi
Is there a way of importing the above file formats directly into Grasshopper. At the moment I am using a grasshopper script to import the file(s) into a particular layer in the Rhino environment. I then use the Dynamic Geometry Pipeline from the Human component to feed it into grasshopper. Works most of the time but I would rather not have stray stl files in the rhino environment and have everything within the grasshopper environment.
Many thanks
William Tiu
Hi William -
You can use the Import 3DM component to import any file format that is supported by Rhino.
Just found a C script written by Laurent Delrieu. Works with binary and Ascii. Many thanks Laurent. Brilliant work.
Hello, can you share the plugin link? Thank you
importing stl format file to Grasshopper - Grasshopper (grasshopper3d.com)
Here you go.
Sorry for the delayed response. Great help. It even allows you to read point cloud.
Thank you.
