Can you post a sample PDF that causes this?
Precisely, how are you importing it? What command, how did your start it? What’s the detailed process you followed?
sorry for the late reply! I can’t share the pdf unfortunately.
but it was a sheet from an architectural drawing set:
MO as follows:
Document properties: Unit settings from meters to feet, absolute tol to 0.0001
Rh cmd: Import, selects PDF, inputs page in question.
Load text = False
Import fills = ‘Boundary curves’
0.907 in in PDF = 15.5 Rh Units
cmd line returns Successfully read file tho:
The sheet imports perfectly; as I can see from the viewport. But at this point Rhino becomes unresponsive.
Windows 10, I7 9700KF, RTX2070s, 48GB RAM
You write that about half of all PDFs cause this to happen. Is there any of those that you can upload here - Rhino - Upload to Support? If you can, please include the URL to this thread in the comments field.
Hi, I’ve experienced similar issues with the file importing and displaying in the viewport but then Rhino hangs and I’m forced to end task. Similarly to Trevor sometimes import PDFs work fine but I haven’t been able to pinpoint what the root cause is.
I had the same problem. I figure that the some “FORMS” (eg.: STAMPS) and/or other interactive Adobe entities have been added to the PDF, Rhino cannot read/process these entities and crashes. Flattening the PDF sometimes solves the issue… but not always
I am using Rhino 7 on PC. It updates itself regularly. I have tried importing and opening. Both fail. Blue wheel of nothing, Rhino unresponsive. The file isn’t that large.
