Hi, I meet an werid problem in RhinoCommon
I drag an invalid (with non-manifold vertices and edges) triangle mesh .obj file into UI to import.
when I picked it, it shows pMesh->IsValid = true
. I guess Rhino did some automatic mesh cleanning during importing stage.
bool SelectErrorMesh(std::shared_ptr<ON_Mesh>& outErrorMesh) {
// pick mesh
RhinoApp().ActiveDoc()->UnselectAll();
CRhinoGetObject go1;
go1.SetCommandPrompt(L"Select Error Mesh");
go1.EnablePreSelect(FALSE);
go1.SetGeometryFilter(CRhinoGetObject::mesh_object);
go1.GetObjects(1, 0);
if (go1.CommandResult() != CRhinoCommand::success)
return false;
const CRhinoObject* pObj1 = go1.Object(0).Object();
const CRhinoMeshObject* pMeshObj = CRhinoMeshObject::Cast(pObj1);
const ON_Mesh* pMesh = pMeshObj->Mesh();
// checkout
ON_wString str;
ON_TextLog log(str);
if (!pMesh->IsValid(&log)) {
RhinoApp().Print(static_cast<const wchar_t*>(str));
return false;
// save mesh
outErrorMesh.reset(pMesh->Duplicate());
return true;
then I save the mesh data into my data structure SPMesh
like:
SPMesh::SPMesh(const ON_Mesh*& rhinoMesh)
:m_rMesh(rhinoMesh) {
// get mesh data
ON_3fPointArray on_vertices = m_rMesh->m_V; // vertices
ON_SimpleArray<ON_MeshFace> on_faces = m_rMesh->m_F; // faces
// save mesh data
Eigen::MatrixXd tempVertices(on_vertices.Count(), 3);
Eigen::MatrixXi tempFaceConnectivitys(on_faces.Count(), 3);
for (int i = 0; i < on_vertices.Count(); ++i) {
tempVertices.row(i) << on_vertices[i].x, on_vertices[i].y, on_vertices[i].z;
for (int i = 0; i < on_faces.Count(); ++i) {
tempFaceConnectivitys.row(i) << on_faces[i].vi[0], on_faces[i].vi[1], on_faces[i].vi[2];
this->vertices = tempVertices;
this->faceConnectivitys = tempFaceConnectivitys;
finally, display it in Rhino. But it shows that mesh->IsValid() = false
ON_Mesh* SPMesh::ToRhinoMesh() const {
int vNum = this->vertices.rows();
int fNum = this->faceConnectivitys.rows();
if (0 == vNum) return nullptr;
// Create ON_Mesh
ON_Mesh* mesh = new ON_Mesh(fNum, vNum, false, false);
for (int i = 0; i < vNum; ++i) {
ON_3dPoint point(vertices.row(i).x(), vertices.row(i).y(), vertices.row(i).z());
mesh->SetVertex(i, point);
for (int i = 0; i < fNum; ++i) {
mesh->SetTriangle(i, faceConnectivitys.row(i).x(), faceConnectivitys.row(i).y(), faceConnectivitys.row(i).z());
mesh->Compact();
// Check mesh
if (!mesh->IsValid()) {
delete mesh;
mesh = nullptr;
return mesh;
Is there something wrong I did in data structrue transformation?
Did i just copy vertices which is not be mesh-cleanning to SPMesh
