Import DXF
I want to create a command to import various dxf files into rhino.
For import I use this command:
Rhino.RhinoApp.RunScript("_Import " + path + " _Enter", false);
This function shows the file selection window, but, I know the path so I want to import it directly, without asking anything.
I’m working with RhinoCommon and c#
Thanks
Add a dash to the beginning of the command name will make it run “as a a script”.
Rhino.RhinoApp.RunScript("-Import " + path + " Enter", false);
There is some discussion of dashed commands in the Rhino help file.
I have solved the problem writting the path in this way
string script = string.Format("_-Import “{0}” _Enter", path);
Rhino.RhinoApp.RunScript(script, false);
Thanks
