UPDATE: Somehow Arc is now creating single span curves for me. Not sure why or what change. Ignore this request.
Request: Arc command create single span curves unless the math requires multiple spans.
The Arc command creates a curve with a minimum of two spans, even when the angle of the arc is one third of a circle or less and a single span rational NURBS curve could be used. (Larger angles require multiple spans.) The superfluous knot results in unneccessary complexity in surfaces, etc created using arcs.
