It doesn’t bother me because I don’t work in ArchiCAD or Revit 100% of the time. I re-model existing beams, columns, walls, windows, etc… With this data, I make alterations / renovations. I would like to know specifically from ArchiCAD users how it is to work with VisualARQ IFC 2x3 exports. For example, if I export a window from Revit, I have a bit more information. Sorry for asking such precise and detailed question. I have to model a building soon…
It is the same as with the walls. When I add or subtract a solid from Rhino, it changes the geometry data (IFC 2x3 export). But if I need to modify a beam or insert decorations, I have to make a Boolean union. The behavior of the IFC data is different to ArchiCAD and Revit!
I have had the plugin for 4 days and so far am very excited! Admittedly I also explore and try out day and night to the smallest detail… Since you also come up with a bit fancy questions
