Anyone have any ideas for new grasshopper components that you would like to see as plugin in grasshopper?
A Civil 3d or Autodesk Infraworks-like plugin. With the ability to design and automate roads, specifically road intersections which is the hardest part, sidewalks, complete with road section, road vertical profiles, road cut , fills & all the necessary object attributes and metadata. Rhino grasshopper is such a great tool to automate urban design. Iāve tried for years but Iām doing a lot but canāt really focus and solve all the problems.
Something I either always wanted to do, or thought its missing in the GH environment.
Solving the wire mess ā Combine wires into kind of wire-groups/bus system. Apply custom colors and so on. Apply something like definition-wide globals, which act as ādefinition-calibrationā. If you specify tolerances, maximum value, constants etc. Why does this needs to be passed by wire? Allow to relay multiple wires from one to another location without hiding it. etc.
Improving on surface tools. For many real-world applications the surface tooling in GH is too weak. Even after more than 10 years we see almost no improvement. That limits GH use-case to a great extend and requires many unnecessary workarounds. However this obviously requires somebody with a decent understanding of the math behind Nurbs, modelling and with sufficient time to implement such a plugin.
runtime assertion, guards, fault handling and unit testing
A generic component to execute any Rhinocommon functionality
A generic approach for Interprocess- and Serial communication
Recursive definitions, Integrate-able definitions.
Code-Generable components.
Signal processing ā e.g Kalman Filter, L/H-Pass, Transfer functions ā¦, which allows you to work on measurements.
Integration of a good math library
Security and Obfuscation
A web platform to actually sell plugins for little money. Food4Rhino is not helping you with this and promotes open-source plugins. With selling plugins the quality of plugins would likely increase. Making a commercial plugin and selling it requires quite an extra effort.Most people either donāt know how to do it, or simply have no time to care about. Like me ![]()
For the first item I highly recommend Telepathy.
Thank you for this hint. I already knew about telepathy. I think its one way of tackling this problem. Sort of. Its a solution for this ācalibrationā problem, where you want to remove the less important parameters. But in general I dislike the idea to hide wires a bit, because it causes the definition to hide relationships in between logical units. You want to reach a high degree of encapsulation, and hiding them might give a false impression of it. This is why I personally would prefer to pipe parameters just a bit cleaner in between my units, but remain the relationship to visible.
Here are some more ideas for GH functionality:
Iāve always wished there was a simple ātableā component inside GH. Something simple - just columns, and rows, that had nice UI (easy group copy-paste / propogation, simple formulas, etc) and then input and output nodes per row and per column. Iām aware of Human and Lunchbox, but Iād rather have just something native to easily array data in a nice grid that didnāt have to rely on a pop-up window (so: actual native widget) and was MacOS compatible. I feel like Iād use something like this all the time where I currently default to a CSV-read operation, or using that āGenepoolā component.
Maybe a stupid suggestion , i donāt know , i am not an expert but i think that when working on massive script ( which is not good practice i know but itās happening all over the world ) a more efficent navigator tool would be very helpfull.
The current one does its job but when if its necessary to remane / reorder the saved view list its not possible.
so i think adding the cpossibility to rename views + the possibility to ad sud level ( same as for regular layers in rhino ) + adding possibility to drag and change order to the saved would be very very appreciated.
i tried to ask it in this thread but i didnāt get any answer
