Hi
I am building a component that outputs a list of Geometry.Points
The input component that gets these accepts a List of Geometry Objects
When I cast them to a GeometryBase a null is returned
igoo.CastTo(out obj)
Basically it seems that the list of Point objects have been converted to Point3d objects
Question : How to transfer Point’s and not Point3d objects ?
Clearly Point Geometry have data attached that I need to read
gd
Grasshopper itself never uses the Rhino.Geometry.Point
type, it always reverts to Rhino.Geometry.Point3d
, which is then wrapped up in a GH_Point
class.
I’ll need to know more about where your points are coming from to answer the question. Are you loading them yourself from a RhinoDoc
? Are they referenced through another component? Are they initially stored in a Generic
or Geometry
parameter? Who is in charge of packaging the data up into the appropriate goo wrapper type?
Hi David
I am generating the Point objects in a Component and passing them as a list in output
The reason is that I need to pass data attached to the points so it was a natural choice using a Point Geometry that is able to keep strings.
Anyway don’t mind I have made a special custom object to pass a list of points and relative data to overcome this issue, it was clear to me reading the docs that in grasshopper points are points.
gerry
Yeah creating a custom data type out of {point + strings}
will be about as much work as co-opting the existing Point class, so it’s probably better going forward.
