How can I change the thickness of the tubular wall as shown in the image?
I want to make it thicker.
Hi Tatsuya - there are a couple of ways you can do this - keep in mind that Rhino is not parametric, in itself (but Grasshopper will certainly let you make a parametric tube).
Sub-object select (ctrl-shift click) the inner or outer wall and scale 2d - this assumes the current CPlane is aligned parallel to the top and bottom of your object. Choose the center of one of the circular edges as the base point for the scale.
Planning ahead, you can make two circles and
ExtrudeCrvto get the tube, using History. Then ModifyRadius or scale, on either circle.
Did you just scale 2D with Gumball? Thats been like my dream forever ![]()
Hello- yes, Shift-drag on the 2d ‘waffle’ icon is a scale 2d.
Thank you much!!
I can do it!
