I need help writing a script/tool for select multi close curves and caculat dim area each of curve sepratly and change color of each curve that is lower than choosen value
i want combin two comand of rhino dimarea and color change for create new customized comand for automate calculating area of houses in dxf plan file
my basic broblem is area dimentional comand only work for one curv in same time i want change this comand for use same time for more then one selected curve
when i edit this command in secend step i combin this command with chang color comand
