I can not flatten the surface
Paluba ispod topa-2 v5.3dm (49.8 KB)
Hello! Can somebody help me to flatten the surface. I am using Rhino just one day.
Thank you a lot for any help.
I attached the file with the drawing.
Are the facets of the mesh intentional? Unrollsrf will not work on meshes, redrawing as a surface is one option.
Here i extractedMeshEdges, then joined the curves and lofted. Unjoined one edge and used Unrollsrf
Paluba ispod topa-2 v5.3dm (434.6 KB)
If the faceted surface is needed, then you can convert the mesh to a NURBS polysurface using ToNURBS or MeshToNURB command. Then UnrollSrf the polysurface.
IMPORTANT - ToNURBS and MeshToNURB simply replace every mesh face with a separate planar NURBS surface, and the surfaces are joined together into a polysurface. The result frequently is too complex to be useful. If you are going to work in Rhino effectively you will need to learn to work using NURBS curves and surfaces.
This drawing is imported from the Fusion as *.OBJ file. I will try to redraw this thing as a surface, but I must see how.
Thank you for the help.
David, thank you!
