HUMAN UI button problem
I am using HUMAN UI button for baking. Very often the button remains in a true state, which causing problems in my definition. How to avoid this?
Any idea?
Actually I am using the button for baking elements.
when you right klick the button you could switch the normal and pressed state true and false settings
It is just a workaround isn’t it? By default it should go back to false state after releasing it…
normally, this works just fine:
bake-hui
