I can’t seem to get this to work. rhinoscriptsyntax wants different stuff from RhinoCommon, but I can’t get either of them working…
import Rhino
count=5
hsl_colors=[Rhino.Display.ColorHSL(i/(count-1),1,1) for i in range(count)]
for color in hsl_colors: print "H={}, S={}, L={}".format(color.H,color.S,color.L)
rgb_colors=[Rhino.Display.ColorHSL.ToArgbColor(color) for color in hsl_colors]
for color in rgb_colors: print "R={}, G={}, B={}".format(color.R,color.G,color.B)
I always assumed that if the luminance was max and the saturation was max that you got the range of pure colors… Simply that the range was 0 to 1 and not 0-255…
Guess that’s wrong then. How would you cycle through the 360° of the color wheel at full saturation then?
It’s not obvious but the type of color in that dialog is HS V not HS L
Set the Saturation to 1 and the Lightness to 0.5 to get the color wheel colors.
import Rhino
count=200
hsl_colors=[Rhino.Display.ColorHSL(i/(count-1),1,0.5) for i in range(count)]
point_obj = rs.AddPoint([color.R,color.G,color.B])
rs.ObjectColor(point_obj,color)
If anyone wonders why I’m playing with this, I was just working on creating a function that will interpolate around the color wheel and return a list of n fully saturated colors. The easiest way to do this seemed to be to work with HSL colors - as they have the notion of saturation - and then convert back to RGB.
The function (below) could be used to color a series of objects or of layers, for example. You can interpolate a portion of the whole wheel by inputting a start value and and end value. Inputting a start/end range of 0 to 1 will interpolate HSL hues directly, otherwise inputting a range from 0 to 360 will convert Rhino color wheel “degrees” to RGB values - 0°/360° is Red, 120° is Green, 240° is Blue…
Anyway, FWIW here it is… --Mitch
import Rhino
def InterpolatedSatColorList(count,start,end):
"""returns an interpolated list of fully saturated RGB colors (via HSL). If
start and end are both between 0 and 1, input will be interpreted as the HSL
normalized domain; else as a degree value between 0 and 360 (color wheel)"""
if start<0 or start>360 or end<0 or end>360: return
if not(start<=1 and end<=1):
#remap from 0-360 to 0-1
start=start/360 ; end=end/360
inc=(end-start)/(count-1)
hsl_colors=[Rhino.Display.ColorHSL(start+(i*inc),1,0.5) for i in range(count)]
return rgb_colors
def TestFunction():
objs=rs.GetObjects("Select objects to color",preselect=True)
if not objs: return
start_hue=rs.GetReal("Enter start hue (0-360 or 0-1)",0,0,360)
if start_hue is None: return
end_hue=rs.GetReal("Enter end hue (0-360 or 0-1)",360,0,360)
if end_hue is None: return
color_list=InterpolatedSatColorList(len(objs),start_hue,end_hue)
rs.EnableRedraw(False)
for i,obj in enumerate(objs): rs.ObjectColor(obj,color_list[i])
TestFunction()
