How to use a ComboBoxCell inside a GridView in Rhino 8 / Eto.Forms?
I am developing a Rhino 8 plugin in C# using Eto.Forms.
I have a GridView with editable cells and everything works correctly with TextBoxCell. Users can edit values directly in the table and the underlying model is updated.
Now I would like to replace some text cells with dropdown lists (ComboBoxCell).
For example, I have columns such as “Limit 1” and “Limit 2” where the user should be able to choose a value from a predefined list instead of typing text manually.
I found several Eto.Forms examples online using ComboBoxCell, such as:
new ComboBoxCell
DataStore = new List
“Option A”,
“Option B”,
“Option C”
Binding = Binding.Property<MyItem, string>(x => x.Option)
However, I am having trouble getting this to work in Rhino 8.
My main issue is that when I click on the cell and select a value from the dropdown, the selected value is not displayed in the cell and the underlying model is not updated.
I also encountered binding errors when trying to use examples found online :
Cannot implicitly convert type ‘Eto.Forms.IndirectBinding’
to ‘Eto.Forms.IIndirectBinding’
Hi @filali_lydia,
Does this help?
– Dale
Hi Dale,
Thank you for the example, it helped me get the ComboBoxCell to display the initial value and open correctly with a single click.
However, I’m still running into another issue:
- The initial value is displayed correctly (e.g. “Test 1”).
- The dropdown opens correctly.
- When I select a different value (e.g. “Test 2”), the cell continues to display the original value instead of the newly selected one.
I reproduced this with a simplified test based on your sample:
```csharp
public class TestItem
public string Value { get; set; }
public class ComboTestDialog : Dialog
public ComboTestDialog()
var grid = new GridView();
grid.Columns.Add(new GridColumn
HeaderText = “Test”,
Editable = true,
DataCell = new ComboBoxCell(“Value”)
DataStore = new string[]
“Test 1”,
“Test 2”,
“Test 3”
grid.DataStore = new[]
new TestItem
Value = “Test 1”
grid.MouseUp += (s, e) =>
if (!grid.IsEditing)
var cell = grid.GetCellAt(e.Location);
if (cell != null &&
cell.RowIndex >= 0 &&
cell.Type == GridCellType.Data)
grid.BeginEdit(cell.RowIndex, cell.ColumnIndex);
e.Handled = true;
Content = grid;
Hi @filali_lydia,
The link above has a full working sample. Did you build and run it?
– Dale
