Great that does work!
You need to move it and do some minor modifications
I posted a simple working example:
#include "stdafx.h"
// BEGIN SampleMeshFaceColor command
class CSampleMeshFaceColorConduit : public CRhinoDisplayConduit
public:
CSampleMeshFaceColorConduit( unsigned int runtime_object_serial_number );
CSampleMeshFaceColorConduit();
bool ExecConduit( CRhinoDisplayPipeline& dp, UINT nChannel, bool& bTerminate );
void setRuntimeObjects(unsigned int runtime_object_serial_number);
private:
unsigned int m_runtime_object_serial_number;
ON_SimpleArray<unsigned int> m_mesh_face_colors;
CSampleMeshFaceColorConduit::CSampleMeshFaceColorConduit( unsigned int runtime_object_serial_number )
: CRhinoDisplayConduit( CSupportChannels::SC_DRAWOBJECT )
, m_runtime_object_serial_number(runtime_object_serial_number)
srand( (unsigned int)time(0) );
CSampleMeshFaceColorConduit::CSampleMeshFaceColorConduit()
void CSampleMeshFaceColorConduit::setRuntimeObjects(unsigned int runtime_object_serial_number)
m_runtime_object_serial_number = runtime_object_serial_number ;
bool CSampleMeshFaceColorConduit::ExecConduit( CRhinoDisplayPipeline& dp, UINT nChannel, bool& bTerminate )
if( (nChannel == CSupportChannels::SC_DRAWOBJECT) )
if( m_pChannelAttrs && m_pChannelAttrs->m_pObject )
if( m_pChannelAttrs->m_pObject->m_runtime_object_serial_number == m_runtime_object_serial_number )
// One time initialization
if( 0 == m_mesh_face_colors.Count() )
const CRhinoMeshObject* mesh_obj = CRhinoMeshObject::Cast( m_pChannelAttrs->m_pObject );
if( mesh_obj )
const ON_Mesh* mesh = mesh_obj->Mesh();
if( mesh )
const int mesh_face_count = mesh->FaceCount();
m_mesh_face_colors.SetCapacity( mesh_face_count );
m_mesh_face_colors.SetCount( mesh_face_count );
for( int i = 0; i < mesh_face_count; i++ )
m_mesh_face_colors[i] = RGB( rand() % 255, rand() % 255, rand() % 255 );
if ( m_mesh_face_colors.Count() )
// store current object's color
CColorVec ObjColor( m_pDisplayAttrs->m_ObjectColor );
m_pChannelAttrs->m_bDrawObject = false;
// Start with the current attributes - always a good idea for proper conforming
CDisplayPipelineAttributes da( *m_pDisplayAttrs );
// da.m_pMaterial->m_FrontMaterial.SetTransparency( 0.6 );
//da.m_pMaterial->m_BackMaterial.SetTransparency( 0.0 );
da.m_pMaterial->m_FrontMaterial.m_bFlatShaded = true;
da.m_pMaterial->m_BackMaterial.m_bFlatShaded = true;
// If we're not drawing surfaces, then we don't want to draw any shaded polygons...
da.m_bShadeSurface = dp.DrawingSurfaces();
// Here's where things can get ugly due the way this conduit is implemented.
// Since the object is always selected (in this example), that means we'll be drawing
// both the shaded polygons and the wires. However, I'm changing this up a little so that
// we don't draw the wires if we're shaded, and instead, I blend the shaded polygons with
// the object's (highlighted) color...
// So, if the object is highlighted AND we're drawing wires AND the original display
// mode is a shaded mode, then we don't want to draw anything. Mesh objects are unique
// in that they can be both drawing wires and surfaces at the same time. Thus, we must
// check for exclusivity on just wires only...
bool bWiresOnly = dp.DrawingWires() && !dp.DrawingSurfaces();
if( da.m_IsHighlighted && bWiresOnly && m_pDisplayAttrs->m_bShadeSurface )
return true; // don't draw anything...
for( int i = 0; i < m_mesh_face_colors.Count(); i++ )
CColorVec color( (COLORREF)m_mesh_face_colors[i] );
// If you want the highlight blending, then just uncomment the 2 lines below.
// since this conduit always runs with highlighted objects, then the following
// code will always get hit, and you will not see your true face colors (ever),
// so you might want to get rid of this altogether. It is only here to show how
// this can be done. However, since you're overriding the drawing of this object,
// then something really should be done about object selection, otherwise there
// will be no way for users to know/see whether or not the object is selected.
//if ( da.m_IsHighlighted )
// color = (color + ObjColor) * 0.5f; // blend the object color with the face color 50/50...
da.m_pMaterial->m_FrontMaterial.m_diffuse = color;
da.m_pMaterial->m_BackMaterial.m_diffuse = color;
da.m_ObjectColor = color;
da.m_MeshWireColor = color;
// Here's yet another situation that you might want to handle. If we're drawing
// shaded polygons, then we might not want to draw the wires. Or if we do, then
// we might want those wires some fixed color. However, keep in mind that hiding
// and showing of mesh wires is controlled by the display mode. But, if an object
// is selected, then its "show wires" flag will always be set at this point. And
// since this conduit only works on selected objects, wires will always be on no
// matter what the user sets in the current display mode. So there is really no
// way to tell if wires should be on of off at this point.
if ( da.m_bShadeSurface )
// We're here because we're about to draw shaded polygons. For now, I'm always
// going to force the wires to be black...
da.m_MeshWireColor = 0;
da.m_bShowMeshWires = true; // not really needed because of what I said above,
// but here for clarity...
dp.DrawFace( m_pChannelAttrs->m_pObject, i, &da );
return true;
class CCommandSampleMeshFaceColor : public CRhinoCommand
public:
CCommandSampleMeshFaceColor() {}
~CCommandSampleMeshFaceColor() {}
UUID CommandUUID()
// {6EA9AC1B-A2FE-4F66-B6BC-D316E9326255}
static const GUID SampleMeshFaceColorCommand_UUID =
{ 0x6EA9AC1B, 0xA2FE, 0x4F66, { 0xB6, 0xBC, 0xD3, 0x16, 0xE9, 0x32, 0x62, 0x55 } };
return SampleMeshFaceColorCommand_UUID;
const wchar_t* EnglishCommandName() { return L"SampleMeshFaceColor"; }
const wchar_t* LocalCommandName() { return L"SampleMeshFaceColor"; }
CRhinoCommand::result RunCommand( const CRhinoCommandContext& );
CSampleMeshFaceColorConduit conduit;
// The one and only CCommandSampleMeshFaceColor object
static class CCommandSampleMeshFaceColor theSampleMeshFaceColorCommand;
CRhinoCommand::result CCommandSampleMeshFaceColor::RunCommand( const CRhinoCommandContext& context )
CRhinoGetObject go;
go.SetCommandPrompt( L"Select mesh" );
go.SetGeometryFilter( CRhinoGetObject::mesh_object );
go.GetObjects( 1, 1 );
if( go.CommandResult() != CRhinoCommand::success )
return go.CommandResult();
const CRhinoMeshObject* mesh_obj = CRhinoMeshObject::Cast( go.Object(0).Object() );
if( 0 == mesh_obj )
return CRhinoCommand::failure;
//conduit= new CSampleMeshFaceColorConduit( );
conduit.setRuntimeObjects(mesh_obj->m_runtime_object_serial_number);
conduit.Enable();
context.m_doc.Regen();
return CRhinoCommand::success;
// END SampleMeshFaceColor command
