When using chatGPT the script I inport into the ghpython node exports goo values instead of points. How to remedy this?
Import necessary modules
import math
Set the number of points in the grid
numPoints = 10
Set the amplitude and frequency of the sine wave
amp = 10
freq = 1
Set the starting and ending points for the grid
startPoint = (0,0,0)
endPoint = (100,100,0)
Calculate the spacing between each point in the grid
pointSpacing = (endPoint[0]-startPoint[0])/numPoints
Create an empty list to store the points
points =
Create a loop to generate the points in the grid
for i in range(numPoints):
# Calculate the x and y coordinates of the point using the sine wave equation
x = startPoint[0] + i*pointSpacing
y = startPoint[1] + amp * math.sin(freq * x)
# Add the point to the list
points.append((x,y,0))
Draw the points in Rhino
for point in points:
rs.AddPoint(point)
